The forum thread discusses issues with Guitar Pro 7.5 on a Windows 7 setup, where the software opens but the icons don't respond, and playback freezes. The original poster seeks help after encountering errors initially and confirms the program works fine on a different Windows 7 laptop. A respondent advises running the program as an administrator, which the original poster confirms has been attempted to resolve the issue.
ghost1
Greetings all. I sure could use some advice about my recently purchased Guitar Pro 7.5 that will not work correctly. I downloaded it on my emachines with Windows 7 and it will open but none of the click on icons on home page operate. I go to top of page and drop down the help tab, with same results. I can open a musical notation, however, when it plays is freezes and acts like it's skipping. I have made sure Windows is up to date. I received a couple of error messages when I first downloaded program that I am attaching, but after deleting and reinstalling program a couple of times, the have disappeared. On a hunch, I downloaded program on our laptop that also runs Windows 7 and it works perfectly on it, but I would really like to use it on the emachine set up. I'm not very tech savvy, but I can follow instructions if any suggestions are given.
Well the second image states "requires elevation" which means you need to be running it as an administrator. Either your computer account isn't an admin or you will need to right click the program and select "Run As Administrator"
Neemobeer
Windows Forum Team
ghost1
Thread Author #3
Thanks Mr. Beer. I did try to run as Admin. That did cause that msg to disappear. I just wanted to post everything that is going on.
