JonathanMoore
BCCode: 4e
BCP1: 00000007
BCP2: 000754EB
BCP3: 00000001
BCP4: 00000000
OS Version: 6_1_7600
Service Pack: 0_0
Product: 768_1
Files that help describe the problem:
C:\Windows\Minidump\020310-36660-01.dmp
C:\Users\Jonnie\AppData\Local\Temp\WER-86939-0.sysdata.xml
Read our privacy statement online:
Windows 7 Privacy Highlights - Microsoft Windows
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
I just don't know what to do anymore. It KEEPS Blue Screening me and I don't know why, if any of you have a solution, I would be happy to hear it, otherwise I'm just going to Install Windows 7 Again.
Did his occur immediately after installing Windows 7? Do you recall installing any new software or making any other major changes to your system?
Are you using the 64-bit or 32-bit version.
Was this a "clean"install or an upgrade?
Go to Start > Run,and type eventvwr. expand the Windows Log section and look for the newest errors.Post back with the Source and EventID
ickymay
please upload your minidump and describe how long the bluescreens have been happening and if it's a pre-built or self-built computer or laptop ?
what antivirus and firewall are you running ?
reghakr
