The user reports a persistent hard disk error on a Windows 8 PC, leading to warnings, slow performance, and failed repair attempts such as chkdsk, sfc /scannow, and DISM. Despite reinstalling Windows, the disk issues and missing DLL errors like odbc32.dll continue, suggesting potential hardware problems. The suggested solution is to run SeaTools, a tool for diagnosing disk health, regardless of the drive manufacturer.
dominict
A few days back, I got an error "Windows detected a hard disk problem". Thinking that it'll fix the problem, I reinstalled windows 8. However, for the past few days I've still been getting the same error when I turn on the computer. I ignore it and I can use my programs and play games without any issue. However, I noticed that my computer runs significantly slowly now. Today, I came home and turned on the computer. Instead of booting into windows, it said "scanning and repairing drive". I left it alone and came back a few hours later and it was booted into windows 8. I logged in and wanted to open up garena to play. Instead of opening up, an error came up saying "the program cant start because odbc32.dll is missing from your computer". I tried reinstalling garena but it does not work.I tried chkdsk but no bad files were found. I tried sfc /scannow but it said "Windows Resource Protection found corrupt files but was unable to fix some of them". Then, I tried dism /online /cleanup-image /restorehealth and it gave an error "DISM failed. No operation was performed." What can I do now?
A few days back, I got an error "Windows detected a hard disk problem". Thinking that it'll fix the problem, I reinstalled windows 8. However, for the past few days I've still been getting the same error when I turn on the computer. I ignore it and I can use my programs and play games without any issue. However, I noticed that my computer runs significantly slowly now. Today, I came home and turned on the computer. Instead of booting into windows, it said "scanning and repairing drive". I left it alone and came back a few hours later and it was booted into windows 8. I logged in and wanted to open up garena to play. Instead of opening up, an error came up saying "the program cant start because odbc32.dll is missing from your...
try running an application called SeaTools. It's a Seagate application which checks on the status of the HDD . It doesn't have to be a Seagate drive as it will work on almost any drive:
SeaTools | Seagate
