rockyspk
Hi every body! I'm a new member. please help me!
1/ I want to use some system tools, but i can find that folder by START->ALL PROGRAM->ACCESSORIES->..at here i can not find SYSTEM TOOLS icon
2/ I want to hide text next to the icon on QUICK LAUNCH bar.
thanks for visit my thread!
ondoy4759
Honorable Member
You're on the right path. After clicking [accessories] you should see [system tools] right near the bottom of the submenu. It has been there all the time.
mike2k9
As for question 2, right click the toolbar (or quick launch and it needs to not be locked) and uncheck the show title and show text options.
davehc
That is interesting.
I do not have that right click option??
The only way I have succeeded is by
1. Right click on empty section of the Taskbar, then select Properties.
2. Under Taskbar menu, go to Taskbar buttons dropdown box and change to Always combine, hide labels from either Never combine or Combine when taskbar is full.
