The user initially sought help with reverting from Windows 8.1 to Vista after encountering a blurry, low-resolution screen issue caused by trying to boot an ISO from BIOS. Responders asked for additional details about the specific problems and system specifications, but the original poster later indicated the issue was resolved. Overall, the thread focuses on troubleshooting booting and display issues related to attempting to install or revert to Vista from Windows 8.1.
CharleyHustle
I'm running Windows 8.1 currently, has worked fine for the time I've had it but want to go back to Vista (Just ran good on my system). I tried to boot the .iso from BIOS when I restarted but had an issue. Ever since I did that my screen has been blurry and on 800x600 resolution. Tried updating the drivers, but didn't change it. How do I get it back to how it was before??
Hey, how do I find out my system specifications? I'm still running 8.1 32-bit because I can't seem to boot to Vista cd. I tried to boot from the DVD-drive in Bios, and didn't work and started up Windows 8.1 as usual, but it changed the screen resolution and heavy blurred lines all across my screen now. Let me know what info I need to give you, this is driving me crazy
CharleyHustle
Thread Author #3
Hi Charley,
we must be in different countries due to the time difference but you managed to solve the issue?
