firewire
Honorable Member
I have a Gigabyte X570 Aurous Master mobo. PC health check says that my PC can't run Win 11 because I don't have secure boot. I've looked in the BIOS (under Boot menu) and I don't see secure boot anywhere.
Would anyone know, does the Gigabyte X570 Aurous Master support secure boot?
they offen hide secure boot under CSM so you normally have to disable it for the option to show
An image from 'Help with Gigabyte Mobo and Secure Boot'. BIOS setup screen showing Secure Boot option highlighted for configuration.
enable secure boot and you should be good to go now... run another PC health check and see
ussnorway
Windows Forum Team
yes it does
there are a lot of bios updates for that old board but before flashing anything go into your bios; in advanced, normally under the settings tab look for something like "Platform Trust Technology" [sometimes its just PTT] and enable it
ussnorway
Windows Forum Team
please post a screenshot or image of your advanced settings
  • Trusted Computing?
ussnorway
Windows Forum Team
i need to see advanced settings i.e click [advanced] then [settings] please
An image from 'Help with Gigabyte Mobo and Secure Boot'. The images show the 'Settings' tab highlighted under the 'Advanced Mode' menu.
ussnorway
Windows Forum Team
ok yours is the Amd board, yes you have ftpm turned on... if you click the "trusted computing 2" do any options pop up?
also what CPU chip is installed?
ussnorway
Windows Forum Team
the processer is fine for w11 and your board has its firmware turned on to let Microsoft hack into your chip so it should take the upgrade
now post the boot tab please temp disable CSM if its enabled
An image from 'Help with Gigabyte Mobo and Secure Boot'. Screenshot of a BIOS/UEFI menu highlighting the Boot tab with a yellow arrow.
ussnorway
Windows Forum Team
