My primary storage device is an SSD, all of the program giles are stored there and recently my PC started complaining there was no more room in my SSD and i should free up some space. Me being stupid, decided i should move the program to my much larger HDD, however, Windows decided to copy the files instead of simply moving them. I though this was not a problem and so i deleted the original files. This went okay until i started getting multiple messages warning me i was deleting system files, and so i stopped deleting. (It still deleted roughly half of what i asked it to). My PC still works perfectly but every time i boot it up i get 4-5 messages letting me know that certain files cannot be found etc. Do i have to wipe my PC to fix this? It's only a minor inconvenience so i don't really want to do this. Thanks for the help in advance. (P.S, Since i upgraded to windows 10, the time it takes for my PC to boot up from pushing the power button to ready to use has increased significantly, is there a way to fix this, or is that just the way things are? Thanks)
The thread discusses a user's issue after attempting to move program files from an SSD to an HDD, leading to missing system files and startup warnings. Responders suggest solutions including resetting Windows, performing an in-place upgrade, restoring deleted files, or reinstalling programs properly to fix the problem. The overall sentiment emphasizes caution with drive migrations and recommends regular backups, with some debating the pros and cons of installing programs on non-C: drives.
Similar threads
- Article
- Article
- Article
- Article
