The thread discusses concerns about increased CPU temperatures after switching to Windows 11, with some users noting temperature rises from around 39-50°C on Windows 10 to 55-70°C on Windows 11. One user shares their experience with overclocked Ryzen CPU showing no temperature change, suggesting individual differences. A later comment emphasizes the importance of proper cooling and closing background apps to prevent overheating, while another user reports stable temperatures and overall positive experience with Windows 11, noting the need for a capable processor. Overall, the sentiment is that increased temperatures may be a genuine issue for some but can often be mitigated through system management.
Ciccio2021
Is anybody else noticing their CPU running much warmer with Windows 11?
On W10 it settle between 39 and 50 degrees.
On W11 its running between 55 and 70 degrees
ive had to reapply thermal compound as it dried out (now ordered Artic MX-4)
This isn't good because it can lead to overheating and destroying your motherboard. You can read on softwaretesttips.com what you can do in such situations. But I think that your CPU is overloaded. You need to close all background software. I also had such a problem, and my CPU was constantly overloading, and it was causing crashes of my operating system. I found out that I have too many background apps, so everything started to work normally after I closed all of them. Maybe you have the same problem, and it will help you.
Sonny
Fantastic Member
Mine will maybe jump up to 50 for a few seconds then go back down to the mid 30's or upper 30's. I can't complain.
Xamalia
I am using ryzen 5 3600x (20% overclocked); cooling - deepcool castle 240ex. There were no changes in temperature, or in the speed of the pump and coolers. I think your problem is individual.
liamsoren
Active Member
michaely
It's pretty weird. My CPU temperature is the same as before. It was around 30-35 degrees, and it stayed that way. Overall, I liked Windows 11 itself. I was a bit too prejudiced at first. Although, to be honest, I've noticed for years how hard it is for me to switch from one operating system. But I was wrong in this situation. Windows 11 has fully vindicated itself. As for me, it even behaves better in terms of optimization. But it would be best if you had a fairly powerful processor. There are a lot of options now. For example, intel k vs kf. These two lines are good but also slightly different. I recommend reading them here digitalmasta. Always keep a close eye on your computer's temperatures.
