Overheating on Windows 10 or Windows 11 is usually resolved by identifying the workload that is keeping the CPU busy, clearing blocked airflow and dust from the cooling system, and using a balanced power configuration rather than an unrestricted performance mode. Start by checking temperatures and CPU use, then clean the vents and fans safely, and finally reduce the processor’s maximum power if heat remains excessive. This guide supports Windows 10 and Windows 11 desktop PCs and laptops.
Prerequisites and compatibility​
You need:
Quick walkthrough
  • A working Windows 10 or Windows 11 PC that can stay on long enough to troubleshoot.
  • A stable, hard surface with unobstructed vents. Do not test a laptop on bedding, a couch, carpet, or your lap.
  • Compressed air intended for electronics, if cleaning is required.
  • A small screwdriver only if your desktop case or laptop manufacturer’s service instructions permit opening the device.
  • Your PC manufacturer’s support app or firmware setup utility, if available, for checking hardware temperatures or fan modes.
Windows does not provide a universal built-in CPU-temperature readout in the Settings app or Task Manager. Depending on the PC, CPU temperature may be available in the manufacturer’s utility or in the UEFI/BIOS hardware-monitor screen. Use a reputable hardware-monitoring utility only if your manufacturer does not provide one.
Stop using the PC and arrange service immediately if you smell burning, see smoke, hear electrical crackling, find a swollen laptop battery, or the PC shuts off repeatedly even when idle. Do not attempt to open or charge a device with a visibly swollen battery.
1. Establish whether the PC is truly overheating​
  • Save your work and restart the PC:
  • Select Start > Power > Restart.
  • A restart clears many stuck background processes and gives you a clean baseline.
  • After signing in, leave the PC idle for five minutes on a hard, flat surface.
  • Check for an unexpectedly busy process:
  • Press Ctrl + Shift + Esc to open Task Manager.
  • In Windows 11, select Processes in the left navigation if it is not already selected.
  • In Windows 10, select the Processes tab.
  • Click the CPU column header so the highest CPU use appears at the top.
  • Note any application consistently using substantial CPU while you are doing nothing. Common examples include a web browser with many tabs, a game launcher updating in the background, cloud-sync software, video-export software, antivirus scans, or an app that has stopped responding.
  • Close only applications you recognize:
  • Select the app.
  • Select End task.
Task Manager Processes view sorted by CPU usage, with the busiest processes at the top.
Warning: Do not end Windows system processes, security software, or unfamiliar entries merely because they use CPU. Ending the wrong process can close your session, interrupt an update, or make Windows unstable. If you are unsure what a process is, leave it running and investigate the application name instead.
  • Check the CPU temperature using one of these methods:
  • Open your PC maker’s utility, such as its hardware, gaming, thermal, or system-management app, and look for Temperature, Thermal, Cooling, or Hardware Monitor.
  • Or restart into firmware:
  • Hold Shift while selecting Start > Power > Restart.
  • Select Troubleshoot > Advanced options > UEFI Firmware Settings > Restart.
  • Look for a page named Hardware Monitor, PC Health, Thermal, Fan, or similar.
  • Record the temperature at idle and again during the task that normally makes the PC hot, such as a game, video call, or export.
There is no single safe temperature for every CPU. Compare readings with the CPU manufacturer’s specified temperature limit where possible. More important warning signs are sustained thermal-throttling messages, fans constantly running at maximum speed, repeated performance drops under load, or an unexpected shutdown.
To leave UEFI/BIOS without changing anything, choose Exit, Save & Exit only if you made an intentional change, or press the displayed key for exit. The PC will restart normally.
2. Remove the workload causing unnecessary heat​
  • In Task Manager, sort Processes by CPU again.
  • If a browser is at the top:
  • Close unused tabs.
  • End a video stream, web game, or video-conferencing session you no longer need.
  • Disable or remove browser extensions you do not recognize.
  • If Windows Update, a game launcher, cloud storage, or antivirus software is using CPU:
  • Let it finish if the system remains stable.
  • Connect a laptop to its original charger during long updates or scans.
  • Avoid gaming, rendering, or other heavy tasks until the background operation completes.
  • Check startup apps that may add heat every time you sign in:
  • Windows 11: Select Start > Settings > Apps > Startup.
  • Windows 10: Select Start > Settings > Apps > Startup.
  • Turn off nonessential applications that you recognize and do not need immediately after sign-in.
  • Restart the PC after changing several startup entries.
Windows 11 Startup apps settings showing application toggles and startup impact.
Expected result: idle CPU usage should fall after unnecessary background applications are closed or disabled. Fan speed may take a few minutes to reduce because the heat sink needs time to cool down.
3. Restore clear airflow around the PC​
  • Shut down Windows fully:
  • Select Start > Power > Shut down.
  • Wait until all lights and fans stop.
  • Disconnect the power cable or laptop charger.
  • Remove USB devices and other connected accessories if they obstruct access to vents.
  • Move the PC to a clean, hard work surface.
  • Inspect all intake and exhaust vents:
  • Desktop intakes are often on the front, bottom, or side.
  • Exhaust vents are commonly at the rear and top.
  • Laptop vents may be on the bottom, sides, rear, or near the display hinge.
  • Remove any object blocking the vents. Leave several inches of clearance around desktop exhaust areas. For a laptop, use it on a desk or table, not fabric.
  • If the exterior vents are dusty, use short bursts of compressed air from several inches away.
Warning: Do not spray liquid cleaners, household air compressors, or moisture into vents. Do not use a vacuum cleaner directly inside a PC, as static electricity or physical contact can damage components. Do not run a laptop or desktop with loose screws, cables, or panels.
4. Clean dust from fans and heat sinks safely​
For a desktop PC, opening the side panel is normally straightforward. For laptops, only open the bottom cover if the manufacturer permits user servicing and the device is out of warranty or the procedure is explicitly supported.
  • With power disconnected, press and hold the physical power button for about 10 seconds. This helps discharge residual power.
  • Open the desktop side panel or approved laptop bottom cover.
  • Before touching components, touch an unpainted metal section of the desktop chassis to reduce static discharge. Avoid working on carpet.
  • Locate:
  • Case fans.
  • The CPU cooler and its fin stack.
  • Graphics-card fans and heat sink.
  • Dust filters, if fitted.
  • Laptop blower fans and vent channels.
  • Hold each fan blade still with a nonmetallic tool or a clean finger while using short bursts of compressed air.
Warning: Do not allow compressed air to spin fans at high speed. Overspinning can damage fan bearings or generate unwanted electrical current. Do not push tools into the fan hub, motherboard, graphics card, or heat-sink fins.
  • Blow dust away from the heat-sink fins and out through the vents. Clean removable desktop dust filters separately and reinstall them only when completely dry.
  • Inspect for obvious faults:
  • A disconnected fan cable.
  • A fan that does not turn freely.
  • Thick dust packed between a fan and heat sink.
  • A loose CPU cooler.
  • Damaged heat pipes.
  • A bulging battery in a laptop.
  • Reinstall the panel or bottom cover and tighten only the screws you removed. Reconnect power.
  • Start the PC and listen briefly. Fans should normally spin during startup, although some desktop graphics-card fans do not run until the card warms up.
Expected result: fans should have a clear path for air, and temperatures under the same workload should be lower or take longer to rise.
5. Use a cooler Windows power configuration​
Use this step when the PC runs hot during ordinary work, when it is placed in a high-performance mode, or when cooling improvements alone do not solve the problem.
Windows 11: Select a less aggressive power mode​
  • Select Start > Settings > System > Power & battery.
  • Expand Power mode, if necessary.
  • Select Balanced or Best power efficiency.
Windows 11 Power settings showing the Power mode control for choosing a less aggressive power mode.
Use Balanced first if you want normal everyday performance. Use Best power efficiency if heat, fan noise, or laptop surface temperature is the priority.
If Power mode is unavailable or cannot be changed, disconnect battery saver or energy saver if it is active, connect the laptop to AC power if required by the device, and check whether your PC manufacturer’s utility is controlling the thermal mode.
Windows 10: Select the Balanced plan​
  • Select Start > Settings > System > Power & sleep.
  • Under Related settings, select Additional power settings.
  • In Control Panel, select Balanced (recommended).
If you see a manufacturer-specific performance plan selected, switching to Balanced is a safe first test. No restart is normally required.
6. Limit peak CPU heat if Balanced mode is not enough​
This is a useful, reversible option for laptops that become uncomfortably hot or desktops that throttle during sustained workloads. Setting the processor’s maximum state to 99% commonly reduces peak heat by preventing the most aggressive boost behavior, though the exact result depends on the CPU and firmware.
  • Open Control Panel:
  • Press Windows key + R.
  • Type control.
  • Press Enter.
  • Select Hardware and Sound > Power Options.
  • Next to the active plan, select Change plan settings.
  • Select Change advanced power settings.
  • Expand Processor power management.
  • Expand Maximum processor state.
  • Set:
  • On battery: 99% for a laptop.
  • Plugged in: 99% if heat remains a problem while connected to power.
  • Select Apply, then OK.
  • Restart Windows, then repeat the same workload used in Step 1.
Expected result: the CPU may run somewhat slower during heavy work, but fan noise, temperature spikes, and thermal throttling should decrease.
Rollback: Return to Control Panel > Hardware and Sound > Power Options > Change plan settings > Change advanced power settings > Processor power management > Maximum processor state, change the affected value back to 100%, then select Apply > OK. No recovery media or registry changes are involved.
Verification of success​
After cleaning and tuning power, verify the result under the same conditions used before:
  • Start the same game, meeting, browser workload, or export task.
  • Observe CPU temperature and fan behavior for at least 10 minutes.
  • Confirm that:
  • The PC does not shut down or restart unexpectedly.
  • CPU temperatures are lower, more stable, or remain below the CPU maker’s limit.
  • The fan does not stay at maximum speed during light work.
  • Performance remains acceptable.
  • The PC’s case or laptop palm-rest area is warm rather than painfully hot.
Alternate method: Use the PC manufacturer’s thermal mode​
Many laptops and some prebuilt desktops include a manufacturer utility that controls fan curves and CPU/GPU power limits. Look for settings named Thermal Mode, Cooling Mode, Fan Profile, Quiet, Balanced, Performance, or Turbo.
For overheating, choose Balanced, Cool, or Quiet rather than Turbo or Performance. A restart may be required by the manufacturer utility.
Do not change UEFI/BIOS voltage, overclocking, fan-curve, or memory settings as a beginner troubleshooting step. Incorrect firmware changes can cause boot failures, instability, data loss during crashes, or reduced component life. If you previously enabled an overclock or aggressive performance profile, restore the manufacturer’s default or balanced profile before making further changes.
Troubleshooting and escalation​
The PC is hot, but CPU use is low​
Check the graphics processor, especially during games, video editing, external-monitor use, or browser video playback. A CPU temperature check alone may miss a graphics-card cooling problem. Confirm that graphics-card fans spin under load and that their intake is not blocked.
On a laptop, also check for a charger that is extremely hot, a blocked rear hinge vent, or a power profile controlled by the manufacturer’s utility rather than Windows.
Temperatures rise rapidly after cleaning​
Check that all fans are connected and spinning. For desktops, confirm the CPU-cooler fan is connected to the motherboard header labeled CPU_FAN or its equivalent. If the CPU fan does not spin, the cooler is loose, or the PC displays a CPU fan error, shut down and arrange repair.
Do not remove and reinstall the CPU cooler unless you are prepared to clean and correctly replace thermal compound. A poorly seated cooler or incorrect thermal-paste application can make temperatures worse.
The PC shuts down before Windows loads​
This points to a likely hardware or firmware-level heat problem rather than a normal Windows setting. Turn it off, disconnect power, check for blocked vents and failed fans, and seek professional repair if the shutdown continues. Do not repeatedly power-cycle a system that is immediately shutting down from heat.
The 99% processor setting makes the PC too slow​
Return the Maximum processor state setting to 100%. Instead, keep the CPU at 100% and use Balanced power mode, reduce demanding application settings, improve airflow, or use the manufacturer’s Balanced thermal profile.
The PC overheats only while charging​
Use the original or manufacturer-approved charger and cable. Avoid charging on soft surfaces, and check whether the manufacturer utility has a high-performance or rapid-charging mode enabled. If the battery swells, the charger becomes unusually hot, or charging causes sudden shutdowns, stop charging and have the PC serviced.
Fans are loud after Windows updates or a driver update​
Restart first, because Windows may still be completing maintenance. If high CPU use persists after an hour at idle, identify the process in Task Manager. If the issue began immediately after a graphics, chipset, or manufacturer utility update, install the current driver package from the PC or component manufacturer rather than using an automated driver-updater tool.
Cleaning and power tuning do not lower temperatures​
Escalate to hardware service when the PC still thermal-throttles or shuts down with clear vents, functioning fans, a balanced power profile, and no unusual background CPU load. Likely causes include dried thermal compound, a failing fan, a blocked internal heat sink, a failing liquid cooler, a loose heat pipe, or an aging battery or power component.
