A Windows PC that “shuts down” but leaves its fans spinning, RGB lights glowing, or USB devices powered is not always suffering the same problem. That distinction matters. A keyboard’s LEDs staying lit can be normal standby power supplied by the motherboard; a PC that restarts, wakes, or never stops its fans is a different beast entirely.
The fastest way to solve it is to establish what remains active, then work from Windows power settings outward to drivers and firmware. Do not begin by randomly toggling BIOS switches like a casino gambler with a screwdriver.
A moody desktop gaming setup with a blank monitor, glowing PC, and day-and-night keyboard startup diagrams. First: identify the symptom​
Use this quick triage before changing settings:
Quick walkthrough
  • Only USB power or motherboard lighting remains on: Windows may have shut down correctly, while the motherboard continues supplying standby power to selected ports or lighting controllers.
  • Fans continue running indefinitely: The system likely has not completed its power-down sequence, or firmware/hardware is holding the platform awake.
  • The PC shuts down, then starts again: A wake source, power event, firmware setting, or physical power-button issue is more likely.
  • The display goes dark but the PC remains active: You may be entering Sleep or Modern Standby rather than shutting down.
Microsoft distinguishes a normal shutdown from sleep and hibernation. Modern Standby systems can look off while remaining in a tightly managed low-power state, so screen-off is not proof that the PC has shut down.
1. Turn off Fast Startup as a diagnostic test​
Control Panel opens the Power Options system settings page for choosing what power buttons do, including Shutdown settings and the Turn on fast startup checkbox when available.
Fast Startup is designed to shorten boot time by using a hybrid shutdown approach. In Windows 10, Microsoft describes the default shutdown behavior as a hybrid shutdown state that writes the kernel session to disk rather than performing the classic fully off shutdown sequence. It is useful, but it can complicate troubleshooting when drivers or firmware behave poorly around power transitions.
To temporarily disable it:
  • Open Control Panel.
  • Select System and Security > Power Options.
  • Choose Choose what the power buttons do.
  • Select Change settings that are currently unavailable.
  • Under Shutdown settings, clear Turn on fast startup (recommended).
  • Select Save changes.
  • Restart the PC once, then choose Shut down and test again.
If the problem disappears, Fast Startup was not necessarily “broken”; it was likely exposing a driver, device, or firmware quirk during the hybrid shutdown path. Leave it disabled if reliable shutdown matters more than shaving a few seconds from startup.
Test a direct shutdown​
After saving work, open Command Prompt and run:
shutdown /s /t 0
Microsoft documents /s as the shutdown command and /t 0 as an immediate timeout. Avoid adding /f unless necessary, because it forces apps closed and can discard unsaved work.
If this command consistently powers the machine down while the Start-menu command does not, revisit Fast Startup and pending application behavior.
2. Check whether Windows is being woken by a device​
Wake-capable devices are most relevant when a PC is unexpectedly resuming from Sleep or Hibernate. They are less likely to be the explanation for a genuinely powered-off PC with only USB lighting still on. Still, a mouse nudge, noisy USB receiver, network event, or Bluetooth device can make a machine appear determined to rise from the grave.
Open Command Prompt as Administrator and run:
powercfg /devicequery wake_armed
This lists devices currently configured to wake the computer. To see what woke the PC after its most recent sleep transition, run:
powercfg /lastwake
To check for scheduled wake activity, run:
powercfg /waketimers
Microsoft’s PowerCfg documentation confirms that these commands can identify armed wake devices, the last wake source, and active wake timers.
If a mouse, keyboard, USB receiver, or network adapter appears in the list and you do not need it to wake the PC, disable its wake capability:
powercfg /devicedisablewake "device name exactly as listed"
Alternatively, use Device Manager:
  • Right-click Start and select Device Manager.
  • Expand Keyboards, Mice and other pointing devices, Network adapters, and Universal Serial Bus controllers as relevant.
  • Open the device’s Properties.
  • On the Power Management tab, clear Allow this device to wake the computer, if the option exists.
Not every device exposes that tab, and its absence is not evidence of a fault.
3. Update Windows, chipset, network, and graphics drivers​
Power-state failures often live in the awkward handshake between Windows, a driver, and motherboard firmware. Start with Windows Update:
  • Open Settings > Windows Update.
  • Select Check for updates.
  • Open Advanced options > Optional updates.
  • Install relevant driver updates.
  • Restart the PC before retesting shutdown.
Windows 11 Settings app on the Windows Update page with the Check for updates button
Microsoft recommends checking Optional updates for driver updates and, if Windows Update has nothing suitable, obtaining a driver compatible with your Windows version from the hardware manufacturer.
Prioritize updates for:
  • Chipset and platform drivers
  • Ethernet and Wi-Fi adapters
  • Graphics drivers
  • USB and Thunderbolt controllers
  • Storage-controller drivers
  • Docking-station firmware or drivers, where applicable
For a custom desktop, start with the motherboard manufacturer’s support page. For a laptop or prebuilt machine, use the PC manufacturer’s support page first; those packages are commonly validated for that model’s firmware configuration.
Windows 10 users should also recognize the calendar reality: Microsoft Support says free Windows Update security fixes and technical support ended on October 14, 2025. A driver issue may still be fixable, but Windows 11 is the supported long-term destination for compatible PCs.
4. Check firmware settings—carefully​
If Windows reaches shutdown but USB power, lighting, or an immediate restart persists, the remaining decision may belong to the motherboard or laptop firmware.
Restart into UEFI/BIOS and look for settings related to:
  • Wake on LAN
  • Wake by USB
  • USB power in off state
  • Wake on keyboard or mouse
  • Restore after AC power loss
  • Power on after power failure
  • RGB or USB charging while off
Names vary wildly between manufacturers, which is firmware’s traditional way of keeping everyone humble. Change one setting at a time, save, boot Windows, and test a normal shutdown.
If the PC powers itself back on after a power flicker or after reconnecting its power cable, inspect the Restore after AC power loss or similarly named setting. If USB devices stay illuminated after an otherwise successful shutdown, look for a firmware option that controls USB charging or standby USB power rather than assuming Windows is at fault.
Microsoft’s documentation for managed Windows firmware settings confirms that UEFI can control wake-on-LAN and wake-on-power behavior on supported hardware.
5. Separate “USB still has power” from “Windows did not shut down”​
This is the most important practical distinction.
A PC can finish shutting down while certain USB ports still provide 5V standby power for charging, keyboard lighting, or wake detection. In that case:
  • The monitor is off.
  • Fans are stopped.
  • Windows is not running.
  • The PC does not restart on its own.
  • Only selected external lighting or charging remains active.
That is usually a firmware or motherboard power-policy choice, not a Windows shutdown failure.
Conversely, if fans remain running, the power LED behaves as though the system is active, or the machine wakes into a usable Windows session, focus on Fast Startup, drivers, wake settings, and firmware updates.
When to suspect hardware​
Escalate beyond Windows settings if any of these occur:
  • The machine remains powered with fans running after Fast Startup is disabled and drivers are updated.
  • It powers on immediately after shutdown even with wake settings disabled.
  • The power button is physically sticking or intermittently registering presses.
  • The behavior started after adding RAM, a GPU, a USB dock, or a PCIe expansion card.
  • The PC behaves the same way from a clean Windows installation or outside Windows troubleshooting.
At that stage, disconnect nonessential USB devices and docks, test again, and consult the PC or motherboard manufacturer’s support documentation for model-specific firmware and power behavior.
The practical fix order​
For most Windows 11 and Windows 10 shutdown problems, use this order:
  • Disable Fast Startup and retest.
  • Run powercfg /devicequery wake_armed and review wake-capable devices.
  • Update Windows, then install appropriate chipset, network, graphics, and firmware updates.
  • Review UEFI/BIOS wake, USB standby-power, and AC-recovery settings.
  • Treat persistent fan activity or spontaneous power-on as a likely firmware or hardware issue.
A shutdown should be boring: click Shut down, fans stop, workday ends, dignity remains intact. If lights alone remain on, however, the PC may be doing exactly what its motherboard was told to do.
