BGR's roundup lists the usual suspects: debris blocking air vents or cooling fans, gaming, running too many applications at once, old thermal paste, and a failing cooling fan. BGR's fixes are a USB cooling pad or fan, compressed air, fresh thermal paste, and the free Fan Control utility. The sections below put those fixes in a safer order. They lean on manufacturer guidance from ASUS and Intel, which BGR does not cover.
Step 1: Rule out software before touching hardware
A hot mini PC isn't always a dirty one. ASUS says that gaming, video editing, conversions or heavy data processing raise CPU and GPU temperatures, and the fan speeds up in response. (That ASUS passage is paraphrased from its Windows 11/10 overheating guide.) In other words, a loud fan under a heavy load is the cooling system doing its job.
ASUS and Intel both point to Task Manager as the first check:
- Press Ctrl+Shift+Esc to open Task Manager.
- Open the Processes tab and sort by CPU (then memory).
- Look for anything using far more than you'd expect. Intel's advice for noisy fans is to check for background software you don't recognize, then select it and choose End task.
- If the fan calms down after you end a process, you've found the cause, and no hardware work is needed.
One caution from ASUS: some models don't spin the fan at all until the system reaches a certain temperature, as an energy-saving design. A silent fan at idle isn't a fault.
Step 2: Fix placement and airflow (free)
This is the cheapest fix and the one most often skipped. ASUS's guidance is to:
- Put the device on a firm, flat surface such as a desk or table, not a sofa, pillow or bed.
- Keep the ventilation holes clear, with some distance around all vents.
- Use the device within the ambient range given in its manual. ASUS cites 5°C to 35°C (41°F to 95°F) for its own products, so check your maker's figure rather than assuming it applies to every brand.
Intel's NUC troubleshooting starts the same way: look for obstructions around the air vents and move the unit to a well-ventilated area. Don't tuck the mini PC behind a monitor, in a cabinet, or under a pile of paper.
Step 3: Clean the dust, gently
Dust is a common culprit in the troubleshooting guides. ASUS notes that dust, hair and cigarette tar can build up on fan blades and heatsinks, and that the sticky residue attracts even more dust.
If you clean it yourself, ASUS's approach is conservative:
- Shut the device down and unplug the power cord.
- Use a commercial can of compressed air, not an air compressor. ASUS says excessive pressure has damaged fan blades.
- Keep the can at a distance from the vent and don't turn it upside down while spraying.
- Use short bursts. A third-party guide from EveZone recommends controlled bursts aimed along the vents and away from the fan blades.
For heavy buildup, ASUS suggests contacting its customer service rather than going further. That's sensible advice if your mini PC is under warranty.
Step 4: Consider a pad or USB fan, with realistic expectations
BGR describes cooling pads that blow air up at the underside of the mini PC, with a $20 cooling pad or a USB fan as the budget route. It quotes about $39 for one aluminum stand and about $34 for one USB fan. It also says options start around $15 to $20, and prices come from the article, not from a check we ran.
Treat these as a possible helper, not a proven fix:
- ASUS only mentions a cooling pad or stand in the context of laptops. Nothing in the manufacturer guidance reviewed validates pads for every mini PC.
- BGR offers no test data showing temperature drops.
- A sensible rule is that an accessory must never block the mini PC's own intake or exhaust. Moving the vents out of a cramped spot will often do as much as adding a fan. That's my judgment from the sources, not a measured result.
- Your mini PC's design matters. Some units draw air through the bottom, so a stand that lifts them may help. Others vent out the back or sides.
Step 5: Check fan settings and firmware
Software and firmware can change how aggressively a mini PC cools itself. The settings are model-specific, so don't assume yours match the examples.
ASUS devices (Windows 11/10): ASUS says most models let you pick a fan mode in the MyASUS app under Device Settings. Some models show ASUS Intelligent Performance Technology and others show Fan Mode. Available modes vary by model. For some commercial desktops, ASUS says Performance Mode keeps the fan spinning under light load.
Intel NUC: For the specific warning "System has recovered from an over-temperature condition," Intel lists these steps:
- Check for blocked vents and move the NUC somewhere well ventilated.
- Optionally load BIOS defaults: press F2 at boot, F9 to load defaults, then F10 to save and exit.
- Try different fan settings: in BIOS go to Advanced > Cooling, and in the CPU Fan Header pane try Fan Control Mode set to Balanced or Cool. Press F10 to save and exit.
- Update to the latest BIOS for your NUC.
- If it still overheats, contact Intel Support.
Intel's article covers specific NUC laptop kit and element products, so don't take these menu paths as a recipe for other brands.
BGR also suggests the free Fan Control utility for tweaking cooling behavior. Whether it works depends on your hardware exposing controllable fans, so check compatibility before relying on it.
Step 6: Thermal paste is a diagnosed repair, not routine maintenance
BGR is upbeat about re-pasting: it says you can buy a kit for under $5 and that you may be able to do it without harming the machine. Other sources are more cautious.
- A guide from Laptop Judge says paste replacement is a contact repair, not a universal cure. It won't fix a blocked heatsink or a failed fan.
- EveZone says re-pasting is an option for the tech-savvy but can be tricky on a compact machine.
- Intel's noisy-fan guidance says to inspect the thermal interface material for visible degradation or contamination. It also warns that some materials can't be reused once disassembled.
- Intel adds that the heatsink must be seated properly. If it isn't, the fan will most likely run at maximum speed.
So open the case only after the free steps have failed, and only if you're comfortable with the work. None of the sources I reviewed says whether opening a particular mini PC voids its warranty, so check yours first.
When to stop DIY and call support
Contact the maker if you see any of these:
- Unexpected shutdowns or freezes, or a repeated over-temperature warning.
- A fan that is dead, grinding, or stuck at full speed after cleaning.
- A hardware diagnostic that flags the fan. ASUS says to visit a service center for replacement if its MyASUS fan check finds a problem.
One last warning from ASUS: third-party temperature tools don't measure chassis temperature, and the chassis is much cooler than the internals. ASUS advises against using them alone to diagnose hardware faults. If you do monitor temperatures, treat the numbers as a trend rather than a verdict. No source I reviewed gives a single safe temperature for every mini PC.
The practical order of operations
| Step | Cost | Risk |
| Check Task Manager for runaway processes | Free | None |
| Clear vents, move to a hard, open surface | Free | None |
| Short bursts of compressed air (powered off, unplugged) | Low | Low if gentle |
| Fan mode or BIOS cooling setting (model-specific) | Free | Low |
| USB fan or stand (don't block vents) | About $15 to $40 per BGR | Low |
| Re-paste thermal compound | Low | Higher: opening the case |
The theme is that a mini PC's cooling system is small and has little margin. Start with the free fixes, and treat anything that opens the case as a last resort.
- Cheap Ways To Cool Down Your Mini PC That Won't Damage It bgr.com · 2026-11-08T22:47:00+00:00
- How to Fix a Noisy Fan in Built-in System with Intel® Processors intel.com
- (Windows 11/10) Troubleshooting - Overheating and Fan issues | Official Support | ASUS Global asus.com
