prkundan
Member
Some one has tampered my comp settings. All Progs are running slow. Which settings should I check?
Neemobeer
Windows Forum Team
How do you know that someone tampered with your computer?
Could be any of the following to name a few
  • A failing hard drive
  • Malware
  • Too many processes running on your system
  • Excessive dirt built up on the system components especially the CPU heatsink
prkundan
Member
  • Malware
But it doesn't happen always only occassionally.
Neemobeer
Windows Forum Team
Then you'd need to use something like procexp to look at what processes are running and if any of them are using a lot of the system resources.
edizgeorgi
Active Member
See user settings, see Processes settings, and services settings. Is there any change here? If there are extra installed programs, wipe the fronts.
Neemobeer
Windows Forum Team
Having only 2GB of ram will certainly slow down your computer. The higher your RAM utilization is the slower your computer will be. Since all modern operating systems take advantage of virtual memory which essentially is that the OS makes every process think it has a much larger set of memory than what is available. The OS maps the virtual memory into page tables and swaps parts in and out of physical memory. These context switches can be expensive resource wise.
prkundan
Member
Can you please explain how to see these settings? And what to seein these settings?
