The original poster, marko, reports font display issues in Windows 7 with .pfm Type 1 fonts—some not showing in applications like InDesign CS3 and BSPlayer, particularly on the 64-bit version. A response from ChatGPT outlines potential causes, such as compatibility problems with legacy fonts on newer Windows systems, especially 64-bit versions, and suggests reinstalling fonts, converting them to more supported formats like OpenType or TrueType, updating software, and refreshing the font cache. Overall, the thread highlights typical font compatibility challenges when upgrading to Windows 7 and encourages solutions like font conversion or software updates.
themre
hey
I've installed latest RC windows 7. on one computer i have 32-bit version, on other 64- bit. on 32-bit version i have a lot of .pfm (type 1) font. but it doesn't show me all. for example i have a ful futura package, but in indesign cs3 and bsplayer i don't see futura T EE Book. worse is on 64-bit version. there i see NO .pfm fonts. is there a bug or what?? thanks for any help.
another thing... on 32- and 64-bit Vista this font worked, so it's nothing wrong with font.
marko
Hello Marko, It seems like you are facing font display issues on Windows 7, with some Type 1 (.pfm) fonts not showing up in certain applications like InDesign CS3 and BSPlayer. Here are some steps and information that might help resolve this issue:
Font Installation:​
  • 32-bit Windows 7:
  • Ensure that you have installed the Type 1 (.pfm) fonts correctly on the 32-bit version of Windows 7. You can try reinstalling them to make sure they are properly registered with the system.
  • 64-bit Windows 7:
  • In a 64-bit system, Type 1 fonts might not work as expected due to compatibility issues.
  • Type 1 fonts are legacy fonts and may not be fully supported on newer operating systems.
  • Consider converting your Type 1...
Font Installation:​
  • 32-bit Windows 7:
  • 64-bit Windows 7:
  • Consider converting your Type 1 fonts to OpenType (.otf) or TrueType (.ttf) formats, as they are more widely supported.
    Font Troubleshooting:​
  • Missing Fonts:
  • If certain fonts are not showing up in applications, try restarting the applications or the computer to refresh the font cache.
  • Check if the fonts are available and properly installed in the Fonts folder of Windows.
  • Software Compatibility:
  • Older software like InDesign CS3 may have compatibility issues with newer operating systems like Windows 7. Consider updating your software to a newer version that is fully compatible with Windows 7.
  • Font Formats:
  • Different applications and systems have varying support for font formats. Type 1 fonts may not be fully supported on Windows 7, especially on a 64-bit system.
    Additional Steps:​
  • Consider using font management software to manage and troubleshoot font issues.
  • Verify the font licensing to ensure there are no restrictions causing the fonts not to display.
  • Check for any Windows updates or font-related patches that might address such issues. If the issue persists, you may need to explore alternatives like converting the fonts to a more universally supported format or seeking help from font experts for further troubleshooting. Let me know if you need further assistance or if you have any other questions!
