This thread discusses the availability of the Windows Vista SP1 RTM build 1840, with users initially unable to find or download the files. Contributors confirm that the build 1840 is the genuine RTM version, but the files were temporarily taken offline due to server overload from high download demand. Overall, the discussion reflects interest and uncertainty about accessing the official SP1 RTM files.
emorytech
I saw a link to download the sp1 rtm in the blogs section. All it does is just take me back to the home page of this website. Am I doing something wrong?
U
Unregistered
Guest
what build does your windows media center software version show?
Windows Media Center Version: 6.0.6001.18000 (longhorn_rtm.080118-1840)
S
Spectre
Guest
I found this entry in the Registry...
HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-directx-direct3d10.1_31bf3856ad364e35_6.0.6001.18000_none_50297d65a99216fa
S
Spectre
Guest
These files also are found in the System32 Folder...
d3d10_1.dll
d3d10_1core.dll
highlander
same thing happens on my x64 which has refresh 2... I have the files.. but its reported as dx10. I guess refresh 2 in the end its rtm. They have the same hash.
Datagg
Hello all.....
Im a bit bummed.. The version i obtained😀 shows by right clicking it, as 6.0.6001.17028
So im assuming this isnt final.... Can final 64 bit version be found???
Thanks....
jeremym
i made a mistake 😛
U
Unregistered
Guest
So in other words this isnt the real, final version, so no point in installing?
or is it at least better than keeping the current shitty vista?
Datagg
Could u show picture of this build i downloaded from this forum also, no test mode shown, yet when right click on properties, it shows this build as 6.0.6001.17028
Mine shows this...
Link Removed due to 404 Error
Yet, as said, if I right click on exe and look at properties, it shows 6.0.6001.17028
What odd is that IE shown current though, so im totally not sure what im looking at here...
nihalz
if you go in windows media center and then settings and then general and then about media center and then software version you will see the build
i get 18000
treo650
Here is the NZB file
I installed this x86 version, and it is INDEED the full REAL ONE, (not a test) --no watermark
ps: you need access to a newsserver to DL this.
