The thread discusses an issue where users experience a black screen and are returned to the user selection screen upon logging into their Windows accounts. Multiple users, including the original poster, resolve the problem by performing a system restore to revert to a previous system state and adjusting update settings to prevent automatic installations, which appears to effectively fix the issue. Overall, the sentiment is one of frustration initially, followed by relief after applying the suggested solutions.
Joeljrincon
Turned on my computer and clicked on my admin profile, it blink with black screen and took me back to the user selection screen. I did the same with the other users and it did the same thing... it's frustrating :| I have exams due :-(
What I ended up doing was a system restore. It took my system back to before the update and it's worked ever since. I also changed the settings to only allow it to download and install updates if I approve of them
Averagejoe1211
Joeljrincon
Thread Author #5
I did the same thing too and it worked perfectly. I should look into the settings as well. Thanks mate!
Joeljrincon
Thread Author #6
I you can resolve this problem ? i have a same problem .
Thanks
I did a system restore and did mostly what user Averagejoe1211, above, posted. Hope this helps
