The thread discusses difficulties in transferring files from Windows 7 to Windows 10 using the Windows Easy Transfer and USMT tools. The original poster encounters errors when trying to use USMT, and a responder explains that USMT images are not compatible across OS versions, recommending creating a Windows 7 VM to facilitate the transfer. The original poster expresses confusion about technical terms like ISO and VM, feeling discouraged about the transfer process.
Skynotempty
I used windows 7's easy transfer to save all my files
(PC was Windows 7 Pro, 64 bit)
Upgraded to a Win 10 pc
Used migwiz (usmt 3( with zero results)
Using usmt 4, I got this:
An image from 'MIGWIZ errors going from 7 to 10'. Console output showing repeated errors while extracting files with corrupted filenames.
Aside from the word "might" spelled wrong, I get tons of errors.
I have the migwiz utility, and all related files in the G directory. The same for the saved data file, named SaveData.MIG
Any help would be greatly appreciated.
MIG files are not portable between OS versions if you use the old version to create the MIG file.
To transfer files from Windows 7 to Windows 10 you would need to use USMT 10 on the Windows 7 machine first to create the MIG andthen USMT 10 on Windows 10 to restore them.
I would grab a Windows 7 ISO and create a Windows 7 VM, then restore your files to the VM. From there you can allow VM to host communication and just transfer the files.
Neemobeer
Windows Forum Team
