The thread discusses a recurring issue where right-clicking on specific files in Windows causes File Explorer to crash and restart, while right-clicking on folders or shortcuts works fine. The original poster seeks help to identify and resolve this problem. A suggested solution involves checking the event logs for explorer crashes and running the system file checker (sfc /scannow) to repair potential system file issues.
Guy Weisz
Hi there,
In the last couple of weeks I have a problem with my mouse right button (doesn't matter which mouse I use - Pad, USB, etc).
When clicking on certain files, such as images, pdf, text files or ms-office files, instead of firing the menu, windows explorer resets (File Explorer shuts down, the icons on the desktop disappear for a moment, all open programs minimize and I find myself on the desktop) - similar to what used to happen when I "violently" shut down the Explorer through the Task Manager (which I never do anymore). This means I practically cannot use the mouse right button.
Interestingly, this does not happen when clicking on folders, shortcuts or zip files, all of which are intrinsic to Windows. In these cases I do get the menu as supposed to.
Does anyone have an idea what can it be and how to solve it?
Thanks.
I would start by looking in the event log for a crash log pertaining to explorer.exe it might give you a clue why it's crashing. You may also want to run the consistency checker to see if there are Windows problems that can be repaired.
From a command prompt or powershell prompt type
sfc /scannow
Neemobeer
Windows Forum Team
sfc /scannow
