billy09
lsst week i noticed, that i had 99GB of unallocted. so i extended it to my current HDD.. when i rebooted the computer i had the message 'autochk program not found- skipping AUTOCHECK' and then the computer reboots endlessly. this is a cycle. i have only found one solutiuon on the net and it involved a floppy disk,, which i dont have + i dont think my PC has a drive for it.
Here are my specs:
Dell Dimension
WIndows 7
3GB RAM
2. something GH
SATA HD
I NEED THIS NOW BECAUSE I HAVE TO DO CORSEWORK ON COMPUTER. PLEASE HELP!!! PLEASE!!
thankyo so much!! :)
It seems like you encountered an issue after extending the HDD where your system is stuck in a reboot loop with the error message "autochk program not found - skipping AUTOCHECK." This issue commonly occurs when the boot configuration data is corrupted or if there was a problem during the disk extension process. Here are some steps you can take to try and resolve this issue:
Step 1: Boot into Safe Mode​
  • Restart your Computer: Press the power button to turn on the computer.
  • Repeatedly Tap F8: Start tapping the F8 key immediately after the computer powers on.
  • Select Safe Mode: Choose the "Safe Mode" option from the Advanced Boot Options menu.
Step 2: Run System Restore​
  • Access...
  • Access System Restore: In Safe Mode, go to the Start menu and type "system restore."
  • Open System Restore: Select "System Restore" from the search results.
  • Choose a Restore Point: Select a restore point before you extended the HDD and follow the instructions to restore your system.
Step 3: Fix Boot Configuration Data (BCD)​
  • Access Command Prompt: In Safe Mode, type "cmd" in the Start menu search and select "Run as administrator" to open Command Prompt.
  • Run the Following Commands:
    cmd chkdsk /f /r bootrec /rebuildbcd
Step 4: Use a Windows 7 Installation Disc​
If you have a Windows 7 installation disc, you can try repairing the system using the following steps:
  • Boot from the Disc: Insert the Windows 7 installation disc and boot from it.
  • Repair Your Computer: When prompted, choose the "Repair your computer" option.
  • Startup Repair: Select "Startup Repair" and follow the on-screen instructions.
Step 5: Seek Professional Help​
If the above steps do not resolve the issue, it might be best to seek the help of a professional technician or a computer repair service. Make sure to back up any important data if possible before attempting these steps. If you don't have a Windows 7 installation disc, you may need to consider alternative recovery options or seek assistance from a professional. Let me know if you need further assistance or if you have any questions!
