gianniscfa
Well-Known Member
- Joined
- Jan 24, 2016
- Messages
- 69
hello i have 4 gb ram on my pc.. but on my computer with windows 8 says 3.00 usable.. why? how to fix this? see the screenshot please
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
find out if you system is 32 bit system and if it is the max memory support is 4 but will show 3.5 or 3 sometimes 3.7 please let me know
this is how you get the info, in the start, then run type this --- dxdiag it will tell you if your system is 32 bit or 64 bit if your not to familiar with this method i will tell you a different way
happy that you remember where you dedicated you ram, but the fact is that still should be showing 4gig, not 3.75 where is the rest? and by the way the usable and the actual is not the samething thats wy i ask you to run dxdiag and post it in the room
just becouse it says (usable) that is what it would say when its been changed in the maximum memory yes thats the reason i asked to run dxdiag
