TerryLP
Active Member
- Joined
- Aug 15, 2015
- Messages
- 56
I have been unable to make Windows 10 work properly with folders. First of all it will not create new folders. Clicking on the create new folder does nothing. When I right click on the screen I get no "New" option. The only way that I have been able to create a new folder is to copy an existing folder, empty it, and then rename it.
My second problem is I cannot double click on a folder to open it. The only way that I have been able to open a folder is to right click on it and then click on the "Open" option.
Any help would will be greatly appreciated. Thank you.
