jameso123
Hi everyone,
I recently installed windows 7, but everytime i put the computer to sleep and wake the computer up, the screen is always freezing..
Any help will be very appreciated!
Have you tried optimizing power options, for example setting them to "balanced" ?
Also, Control Panel –> System and Security –> Power Options -> Change Advanced power settings -> Turn Off Hard Disk after -> set 0.
This can also be a driver issue.
cybercore
jameso123
Yes, I've tried that but it didn't work...
