The forum thread discusses issues with a powered USB hub that fails to recognize connected devices, despite the hub receiving power and the drivers being properly installed. Users suggest testing the hub on another computer to determine if the problem is related to the hub or the motherboard, and also note that many powered hubs tend to fail over time, possibly due to manufacturing quality. Overall, the troubleshooting points toward potential hardware issues with the hub, power supply, or device compatibility.
chasemyass
Today I've bought one powered USB Hub that I was hoping to solve my low number of USB ports. It has 10 ports but when I connect anything on it (my phone, my external hard disk, flash disk, etc.) it doesn't recognize it. All of them are working conected directly. No unknown device under Device manager when I have only hub conected so the drivers are up and running. My windows is 7 32b SP1.
Can someone gimme a hand abt this? Thanks!
Sent from my JY-G5
Is the powered hub actually getting power? Maybe the power adapter isn't working. There should be an LED or something to indicate the hub is getting power.
There really isn't any setup required for a hub, just plug it in and it should work. If the hub is getting power then it may just be that the hub is defective.
strollin
Honorable Member
chasemyass
Thread Author #5
Yes it is powered and it gets power. I suspect that my problem is from motherboard, even that I haven't checked the Hub on another PC to see how it works. I'll do that today and write here how it goes.
Sent from my JY-G5
strollin
Honorable Member
Since you say the devices work fine when plugged directly into the USB ports on the computer, I would think the motherboard is working OK. Please do try the hub on another computer and let us know if it works there.
Fixer1234
Sent from my JY-G5
Over time, I have bought over a dozen USB hubs of many different brands. What they all had in common was that every single one failed for no apparent reason. They were all powered through a UPS and none of them was subjected to any form of extreme use. The longest life was probably a year. After wasting a lot of time trying to diagnose problems, I've concluded that they must all be made in the same factory in China and some characteristic makes them especially susceptible to failure. At this point, when one fails I just buy a new one and the problem disappears for awhile.
Joe S
I see over on the WD forum a lot people using powered hubs have problems with the external drives plugged into them. I suspect the voltage is barely adequet for anything that reqires much power. I had one and it seemed to die one port at a time.
Joe
