BarryHWhite
When the PC ran under Vista, it worked with a HDMI connection to a Panasonic TV
I perform a clean install to Windows 7 Professional
The HDMI connection no longer works with any TV and not even to an external monitor
When you encounter issues with HDMI connections after changing the operating system, such as from Windows Vista to Windows 7 Professional, there are a few troubleshooting steps you can take to address the problem:
Troubleshooting Steps:​
  • Check Display Settings:
  • Right-click on the desktop and select "Screen Resolution" or "Display Settings."
  • Ensure that the correct display is set as the primary monitor and that the resolution is appropriate.
  • Update Graphics Drivers:
  • Outdated or incorrect graphics drivers can often cause display issues.
  • Visit the manufacturer's website for your PC or graphics card to download the latest drivers for Windows 7 Professional.
  • Check HDMI Cable and Ports...
  • Check HDMI Cable and Ports:
  • Ensure the HDMI cable is securely connected to both the PC and the TV/monitor.
  • Try using a different HDMI cable to rule out any issues with the existing cable.
  • Test the HDMI ports on both the PC and the TV/monitor to verify they are functioning correctly.
  • Configure HDMI as Default Output:
  • Right-click the volume icon in the system tray and select "Playback devices."
  • Set the HDMI device as the default audio output if required.
  • Restart Windows Audio Service:
  • Press Windows key + R, type services.msc, and press Enter.
  • Locate "Windows Audio" in the list, right-click it, and select "Restart."
  • Try Different HDMI Port:
  • If available, try connecting the HDMI cable to a different HDMI port on your PC.
  • Some PCs have multiple HDMI ports, so testing different ports can help identify if a specific port is causing the issue.
  • Test with Another Device:
  • Connect the PC to another TV or monitor to see if the issue persists.
  • This helps determine if the problem lies with the PC or the original TV/monitor.
  • Check TV/External Monitor Settings:
  • Ensure the TV or external monitor is set to the correct HDMI input channel.
  • Check the TV/monitor settings to verify that HDMI input is enabled and functioning.
    Additional Considerations:​
  • Compatibility: Ensure the HDMI port on the PC is compatible with the TV/monitor.
  • Firmware Updates: Check for any firmware updates for the TV/monitor.
  • Reset TV/Monitor: Power cycle the TV/monitor by unplugging it for a few minutes and then plugging it back in. By following these steps, you can troubleshoot and potentially resolve the HDMI connection issue between your Windows 7 Professional PC and the TV/monitor.
