The thread discusses a Windows computer with minimal disk space, caused by the "System Volume Information" folder. The original poster seeks advice on deleting files within it, and another user explains that the large size is likely due to System Restore and Volume Shadow Copy data. Following the suggested steps to manage shadow storage, the original poster successfully freed up 160GB of space. Overall, the responses are helpful, leading to a positive resolution.
johnsamsung10
hi there. my dads computer has very little hard drive space left, so i downloaded file size t see which flyer was taking all the room away, the folder "system volume information" is using 77.5% of the hard drive and with all the other files photos ext its only got 4.5gb left (223gb hard drive) can i delete these files or not? also ran a virus scan and came up with no issues.
any help appreciated
thanks
This is probably due to System Restore, make sure his computer is set to use a nominal amount of space for System Restore (say %10).
If you want to get into the nitty gritty and learn about how much space Volume Shadow Copy is using, launch an Elevated Command Prompt and check out the following:
vssadmin list shadowstorage (shows storage usage)
vssadmin Resize ShadowStorage /For=C: /On=C: /Maxsize=10GB (sets max size of Shadow Copy Storage to 10GB)
Josephur
Windows Forum Admin
johnsamsung10
Thread Author #3
thank you this worked, now have 160gb free!
