The user is experiencing issues with safely removing external USB devices via a Type-C hub on Windows 10, which causes all connected devices to disconnect and prevents reconnection until a system restart. Testing on Linux shows the hub functions correctly, indicating a Windows-specific problem. The user notes that USB flash drives can be ejected normally through Windows Explorer, but external hard drives lack the "Eject" option, and is seeking a method to enable this for them, potentially resolving the disconnection issue.
olat
Well-Known Member
Hello!
I got a new Type - C USB Hub with 4 3.0 ports.
The hub works great, but the problem is that once I try to safely remove (eject) one of the USB devices, all of them get disconnected.
Furthermore, once I do that, I can't connect any devices again until I restart the PC. They do power up, but windows does not read them.
For example, let's say I connect 3 devices: USB 1, USB 2 and USB 3.
I then click the taskbar icon to safely remove USB 1. There's no option to just remove one, but it says Eject External. Once I click that, all 3 devices are then safely removed.
I then disconnect those devices and reconnect again. None of them are recognized. I don't get any issues, errors or anything.
The only way to have those devices recognized again is to restart the computer.
If I just plug them out without safely removing them (ejecting) first, then they work normally after I plug them in the second time.
I'm using external HDDs a lot, so I always eject them first.
Any help would be much appreciated.
OS Version: Microsoft Windows 10 Pro, 64 bit, Build 19042, Installed 20201020141753.000000+060
Processor: AMD Ryzen 7 3700X 8-Core Processor, AMD64 Family 23 Model 113 Stepping 0, CPU Count: 16
Total Physical RAM: 16 GB
Graphics Card: Radeon RX 580 Series
Hard Drives: C: 222 GB (47 GB Free); F: 298 GB (151 GB Free); Q: 1862 GB (341 GB Free);
Motherboard: Micro-Star International Co., Ltd B450 TOMAHAWK MAX (MS-7C02), ver 1.0, s/n JB16610699
System: American Megatrends International, LLC., ver ALASKA - 1072009, s/n To be filled by O.E.M.
Antivirus: Windows Defender, Enabled and Updated
Thank you!
One more update: if I use a standard usb flash drive, I can right click on it in windows explorer and then click "Eject". This removes the drive and allows me to connect again without issues.
But, I do not have the "Eject" option for usb external hard drives. Is there any way to force it to appear for those devices as well? That might basically solve my issue.
olat
Well-Known Member
Thread Author #2
I just tested the hub on Linux Ubuntu and it works as expected there, no problems. I can unmount separate drives without issues and when I reconnect them they work normally.
olat
Well-Known Member
Thread Author #3
