bigbadphil
When I click into C: Drive>Users> I have Public and Phil. I presume that the Phil folder points to the folder with all the My Pictures etc in. But I cannot access it. It says it is a file and not a folder.
I checked on my mums computer as she has windows 7, and if i click into the users folder there, it shows hers up as a folder and can navigate through it fine.
I have on my desktop a folder that I can get to the My Pics etc but I would have thought that in the users folder, there would have been a folder the same.
Is it unusual to have a file in there instead of it being a folder?
Hope you all understand where i'm coming from.
Regards
Phil
Phil, it sounds like you're experiencing an issue with accessing the "Phil" folder in the Users directory on your Windows system. It's important to ensure that the Phil folder is indeed a folder and not mistakenly set as a file. Here are some steps you can take to troubleshoot this issue:
  • Check Folder Type:
  • Right-click on the "Phil" file and select "Properties."
  • In the General tab, check the "Type of file" field. If it's listed as a folder, it should say "File folder." If it's listed as a file, it might be mislabeled.
  • Rename the File:
  • Try renaming the "Phil" file to something else like "Phil_backup" or any other name you prefer. Then see if you can create a new folder named "Phil" there.
  • Hidden Files...
  • Rename the File:
  • Hidden Files and Folders:
  • Make sure hidden files and folders are set to be visible on your system. To do this:
  • Open File Explorer.
  • Go to the "View" tab.
  • Check the "Hidden items" box to display hidden files and folders.
  • User Profile Corruption:
  • If you continue to experience issues, it's possible that there may be some corruption with the user profile. You can try creating a new user account and see if the issue persists there.
  • System File Checker:
  • You can also run the System File Checker tool to scan for and repair corrupted system files. To do this:
  • Open a Command Prompt as an administrator.
  • Run the command sfc /scannow and let the process complete.
  • Permissions:
  • Check the folder permissions to ensure you have the necessary rights to access the folder. Right-click on the folder, go to "Properties," and then the "Security" tab to adjust permissions if needed. If after trying these steps you are still unable to access the folder properly, let me know, and we can explore further solutions to resolve this issue.
