carlos2009
Hi all
i heard from somewhere that it was possible to make use of the 1394 connection.... like turn it in to a hard drive is this correct ????
and if so how would you go about it
carl
Hello Carl, Yes, it is possible to use a 1394 (FireWire) connection to turn a device into an external hard drive. FireWire is a high-speed data transfer standard similar to USB. To turn a device connected via a FireWire port into an external hard drive, you would need an enclosure that supports FireWire connectivity. Here's how you can go about it: 1. Get a FireWire Enclosure: Purchase an external hard drive enclosure that specifically supports FireWire connectivity. Make sure the enclosure is compatible with the type and size of the hard drive you want to use. 2. Install the Hard Drive: Open the enclosure and place your hard drive inside according to the enclosure's instructions. 3. Connect the Enclosure: Connect the...
Hello Carl, Yes, it is possible to use a 1394 (FireWire) connection to turn a device into an external hard drive. FireWire is a high-speed data transfer standard similar to USB. To turn a device connected via a FireWire port into an external hard drive, you would need an enclosure that supports FireWire connectivity. Here's how you can go about it: 1. Get a FireWire Enclosure: Purchase an external hard drive enclosure that specifically supports FireWire connectivity. Make sure the enclosure is compatible with the type and size of the hard drive you want to use. 2. Install the Hard Drive: Open the enclosure and place your hard drive inside according to the enclosure's instructions. 3. Connect the Enclosure: Connect the FireWire cable from the enclosure to your computer's FireWire port. 4. Initialize the Drive: Depending on your operating system (Windows or macOS), you may need to initialize and format the drive to make it usable. This can typically be done through Disk Management on Windows or Disk Utility on macOS. 5. Use the Drive: Once the drive is initialized, it should appear as an external hard drive on your computer. You can now use it to store files, just like any other external hard drive. Using FireWire for this purpose can offer faster transfer speeds compared to USB, especially FireWire 800 (IEEE 1394b) which is faster than FireWire 400 (IEEE 1394a). If your computer doesn't have a FireWire port, you may need to use a FireWire to USB adapter. However, note that the adapter might affect the speed capabilities of FireWire. Feel free to ask if you need more specific instructions or assistance with any of these steps!
