Hallo Forum,
once I've made a backup of my System-Partition of Windows XP 64 Professional including the MBR. As you can expect by this topic it doesn't work out as expected. To keep it short, after a lot of trouble I'm at the point where it seems that I have the VBR/Bootsektor at partition 2 while the System Partition is partition 1.
... The resulting problem is when I mark partition 2 as active it tries to boot (also) from partition 2 but complains (reasonable) about missing ntoskntl.exe; While when I mark partition 1 as active it *could* find everything on the partition but it just hangs on a black screen with blinking cursor.
I checked the 512 bytes of the 1 partition and from my understanding and research there is a bootsector:
The most confusing/ironic part is: it is the same computer, (pretty) same hardware, even the same physical disk at the same stupid port.
What do I miss?
If you need more information or elaboration do not hesitate to ask.
Thanks in advance
Veps
00000000: eb58 904d 5357 494e 342e 3100 0208 2a00 .X.MSWIN4.1...*.
00000010: 0200 0000 00f8 0000 3f00 ff00 c5fa 3f00 ........?.....?.
What do I miss?
Thanks in advance
Veps
