Hello, this has started a few days ago. I was using my vlc player to view a movie and i noticed that the volume on the player wouldn't go past 200 (max volume is 400). So i opened the volume mixer and there is device (speakers) and applications (system sounds) and then the player. There is a bar that makes it impossible for me to set my volume. This was never here before? Could it be a virus, or malfunctions? If anyone knows how to get rid of this annoying occurance please let me know. I have been trying all types of solutions from various places. If it cannot be resolved, i will just get a mac. Ive been throughly irritated. Thanks in advance!!
The thread discusses an issue where the user’s VLC media player volume is capped at 200 out of 400, and the volume mixer shows a restricted volume bar, causing frustration. Several contributors suggest troubleshooting steps, including checking settings, taking screenshots for clarification, and performing a system restore if the problem started recently. Overall, the conversation centers on diagnosing a possible software or system glitch rather than a virus, with helpful suggestions offered to resolve the issue.
Can you remember a day or date BEFORE this problem arose?
If yes, do a system...
davidhk129
- Joined
- May 19, 2012
- Messages
- 1,315
If yes, do a system restore, pick a date before you have this problem as your restore point.
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
davidhk129
- Joined
- May 19, 2012
- Messages
- 1,315
I sometimes use VLC but couldn't think of the settings you mention:
Could you take a screenshot and post?
He meant this volume mixer......
