The thread discusses a user's issue with a Toshiba laptop running Windows 8 where the headphone jack isn't working despite the port and drivers appearing functional. Responders suggest solutions including installing drivers in compatibility mode and configuring the Realtek audio control panel to enable auto-popup and select headphones when connected. The overall sentiment is helpful, with users offering practical troubleshooting tips to resolve the audio jack problem.
Matei Oprea
Hello,
I have a Toshiba Laptop c660 with windows 8 professional installed. I can`t make the jack for headphones to work. The jack is not broken because it works on Ubuntu.
I installed the driver for my soundboard. Didn`t worked. I unistalled it and i let windows chose the best option for me but still didn`t worked.
What i have to do to make it work ? What should i post here ?
sorry your post was missed until now.
Have you tried installing the sound driver under compatibility mode?
davehc
I think that's a realtek soundboard?
if so, open the Realtek audio icon in the Control panel.
With the headset out, or disconnected, and with the "Speakers Tab" highlighted
Click: "Connector settings" ( top right hand side of the screen)
Click: "Enable auto popup dialogue box"
Click: "OK"
Now plug in the headset
ANother window will pop up.
Select "headphones" as the item plugged in (NOT the line out)
Jimbo22
It took me awhile to figure Realtek's control panel. I had an Asus mobo that VIA HD audio and it's control panel was very simplistic and GUI friendly. The with this Gigabyte mobo...oh holy crap what a learning curve...yep Dave, I floundered around Realteks control and just happened to stumble on that....most excellent tip for user to the Realtek sound panel
malik mohsin
{{{{{{{{ This post is so great and nice }}}}}}}}}
