The thread discusses an issue where the original poster is able to send emails via SMTP without authentication but encounters failures when using authenticated SMTP on HP MFP devices, despite confirming correct credentials. Respondents inquire about testing with CLI tools, error codes, and whether authentication works from other locations or if IP restrictions might be causing the problem. The overall sentiment suggests troubleshooting connection configurations, authentication methods, and potential IP filtering to resolve the SMTP authentication failure.
ramon82
Hi all,
For some reason using an authenticated SMTP I manage to send emails through my HP MFP machines, but when I use authenticated SMTP it always fails.
Any idea why this might be happening?
PS: The authentication username and password are 100% correct.
Thank you all
ramon82
Thread Author #3
SMTP works and is permitted otherwise it wont work on 'authenticated' - the only problem is when I use the username and the password
Neemobeer
Windows Forum Team
Does it work authenticated elsewhere? Is there an IP allow list in place for allowed sending clients?
