Gemini1179
Ok, so I recently purchased a new desktop with Windows 7 Home Premium. At home I have the desktop, an internet router/gateway combo from my ISP, an XBOX360 wired to the router, as is the Desktop, a Samsung UN55C7000 LED TV with wireless connection and a Samsung BD-P3600 Blu-ray player that I do not have connected to the newtork.
My original setup had the computer, XBOX and tv all connected and was able to stream video, etc from my shared folders on my desktop to my XBOX and tv.
Then I got greedy. I removed the wireless connector from my tv and tried connecting my Blu-ray player- to no avail.
It seems my blu-ray player can find Youtube and the internet well enough, but when I tried connecting to my computer, it couldn't find any shared files. After a day of trying everything I could think of and cursing a lot, I removed the wireless USB adapter from my blu-ray and put it back into the tv.
Only now, the tv cannot connect to my desktop to stream video- but can still find the shared folder created by Vuze. So if I want to stream video from my desktop to my tv, I have to use Vuze.
The same thing happened when I removed the wired connection from my xbox and attached it to the blu-ray- BR won't find the computer shared files, and when I re-connected my XBOX, it can't find my regular shared files, in fact, when I ran the "Connect to PC" test, it can only find the Vuze shared folder, and not my PC.
So I've left and rejoined my HomeGroup with my Desktop several times, all sharing is on, the network sees the tv, and xbox as media devices, says sharing is on, but they are no longer seeing the shared folders on the CPU.
Last thing I tried was going to the Media Streaming Options (which had my XBOX and TV set to "ALLOW" this whole time) and removing the XBOX and TV, and then re-adding them.
EXCEPT, there is NO OPTION TO RE-ADD A DEVICE.
So now my my Media Streaming Options are limited to the devices on "All Newtorks" which is my Desktop.
Long story short, HOW can I re-add my tv and xbox? what is going on with my shared folders?
Why does Windows networking become more frustrating with each new version?
Thank you.
It sounds like you're experiencing some network sharing issues between your Windows 7 Home Premium desktop, Xbox 360, Samsung TV, and Samsung Blu-ray player. Network sharing can be a bit finicky, especially when dealing with multiple devices and configurations. Here are some steps you can take to troubleshoot and potentially resolve the issue:
Troubleshooting Steps:​
  • Check Network Settings:
  • Ensure all devices are on the same network (SSID).
  • Verify that network discovery and file sharing are enabled on your Windows 7 desktop.
  • Verify HomeGroup Settings:
  • Make sure all devices are part of the same HomeGroup. You can create a new HomeGroup on your Windows 7 desktop and re-add the devices to it.
  • Check...
  • Check Firewall Settings:
  • Temporarily disable the firewall on your desktop to see if it's blocking the connections. If disabling the firewall resolves the issue, you may need to adjust the firewall rules to allow file sharing.
  • Reset Network Settings:
  • Resetting the network settings on your Windows 7 desktop and reconfiguring the network connections might help resolve the issue.
  • Update Device Firmware:
  • Check for firmware updates for your Samsung TV and Blu-ray player. Sometimes, updating the firmware can improve network compatibility.
  • Manually Add Devices:
  • If the automatic device discovery isn't working, try manually adding the Xbox and TV as network devices on your Windows 7 desktop.
  • Restart Devices:
  • Sometimes a simple restart of all devices (desktop, Xbox, TV, and Blu-ray player) can refresh the network connections.
    Windows Networking Frustrations:​
    Windows networking can indeed be challenging, especially as new versions introduce changes. Each version may have different settings and configurations, leading to compatibility issues. It's essential to stay patient and troubleshoot systematically to identify and resolve any network sharing issues.
    Additional Thoughts:​
    It's worth noting that Windows 7 has reached its end of life, meaning Microsoft no longer provides security updates or support for the operating system. Consider upgrading to a newer version of Windows for better security and compatibility with modern devices. Feel free to try these steps and let me know if you encounter any specific issues or need further assistance with re-adding your TV and Xbox to your network sharing setup.
