The thread discusses an issue with Windows-based Wi-Fi connectivity where the user experiences a Winsock error 10060, indicating a connection timeout, despite successful ping tests and a functioning wired connection. Suggestions include resetting Winsock via command prompt, which the user tries unsuccessfully. A more detailed diagnosis is recommended, including sharing system specifications and checking wireless drivers, as the problem might be related to hardware or driver issues.
Hi Prashp1:
Saltgrass gave you what I like to call one of the "magic beans" solutions. That works in many cases, and appears to be magic when it fixes it! Unfortunately you may have some other issues with your networking. It would help us to help you identify and resolve the problem if you woudn't mind posting your computer specs here. Is it a Desktop or a Laptop? Make and Model, CPU, RAM memory and type, Hard Drive make/model/capacity used; etc. If you don't have that at hand, I suggest you Google the SPECCY program, and download/install/run AND zip up the results back here when you're all done so we can better assist you.
Did your computer come with Windows8 installed? Or did you upgrade it from an earlier version of...
- Joined
- Oct 16, 2009
- Messages
- 15,153
I am not the networking guru around here, but you might try resetting the winsock using an Command Prompt and type the following. I don't think it needs an Administrative command prompt, but if it won't run, us that version of the Command Prompt.
netsh winsock reset
I will tell you to reboot your system after the command completes.
netsh winsock reset
netsh winsock reset
I tried this and it did not work. Still the same error message.
- Joined
- Jan 28, 2013
- Messages
- 2,423
Hi Prashp1:
Did your computer come with Windows8 installed? Or did you upgrade it from an earlier version of Windows such as Win7 or Win Vista?? If so, it could very easily be a driver issue with your internal Wireless card (WLAN) driver. If you did upgrade, did you go the computer manufacturer's website and download/install the latest driver for that WLAN card?
Looking forward to seeing your information.
BIGBEARJEDI
BIGBEARJEDI
