Saaiberke
Hello,
I installed the lanchat program Softros LAN Messenger on build 7068, the program was working fine but it stopped working after installing build 7077. I did a fresh install of build 7077 and a fresh install of the program.
Does anybody know what exactly changed between the 2 builds and what can causing this program to crash now? I tried all possible compatibility modes but it still doesn't work.
The error I see: An internal exception occured (address:0x0)
After I press ok I see: The application was unable to start correctly (0xc0000142)
Grtz,
Nic
intwtl
I have had the same problem with:
Slingplayer software
Holdem indicator
Kavoom (km software)
Other than that 7077 seems faster and very stable.
Saaiberke
I contacted the software authors and they gave me a debug version to report the problem back to them. Now the strange thing is that this debug version runs without any problem :)
Nic
Cheena
I too am having the same problem with Siglos karokee software, they said it workes with vista which I haven't tried yet. I will have do a partition to see if this is so.
