The thread discusses various solutions for transmitting PC display content wirelessly or via RF to multiple TVs. The original poster highlights an existing method using HDMI to RF converters and antennas, suitable for large areas with multiple devices, but with limitations like resolution drop and lack of encryption. An alternative "full HD" RF broadcast solution involves using HDMI to ATSC RF modulators, making it ideal for public settings like sports bars, with discussed equipment costs and setup considerations. Overall, the conversation centers on affordable, unencrypted methods for broadcasting PC video to multiple screens over RF.
Thread Author
I worked on a solution to cast unsupported PC to unsupported Miracast device for over a year and placed the solution in an official WIKI page in July of 2021.
stream_pc_chromecast [Serviio Wiki]
_______________________________________________
Below is a different solution that uses an unencrypted way to connect to any screen/s that supports RF (radio frequency) signal that is within range. It is a type of a wireless display splitter that is only limited by the range of the signal and not the number of the devices.
Johncoool
Thread Author #2
Alternative way for wireless display on any TV.
The other way is to use HDMI to RF converter.
HDM68 is a device that converts HDMI to RF. I have the HDM69 which converts HDMI or RCA connection signal to RF signal.
The requirements are:
HDM68 or 69 device or a similar device that works on the same principle.
One HDMI cable.
Two indoor TV antennas. (Check the TV antenna connector because not all are the same. An adapter connector can be used as I did for one of the two Antennas.)
All TVs still have RF connection. But make sure that the port is on the TV before making any purchases.
The Setup:
Connect one Antenna to the signal converter and one Antenna to the TV.
Connect the HDMI cable from the PC to the HDM68(9).
Extend or duplicate PC screen depending on the requirement.
Switch on the converter device (select HDMI port if available) and then go to the setting in the TV menu. Use auto Search to search for channels. Stop it after it finds your display.
Audio and Video will now work on the TV.
The advantages of this solution are:
Infinite number of TVs can be connected that are with in range. Works through walls (up to a certain limit). Works with any HDMI device. The RF signal can be picked up by any RF receiver including radio that works on the same bands. So Audio can be picked up from a HI-FI system if it meets the requirements.
The disadvantages are:
The resolution drops and is not too good for text but it is good enough for video.
No encryption, so anyone with an Antenna can pick up the signal that is with in range.
RF = Radio Frequency
Johncoool
Thread Author #3
There is an untested solution to broadcast using RF with full HD resolution..
One is HDMI extender over WIFI. But this will only be point to point.
The other way is the same as using the previous solution with the HDM68(9) device.
But the other device is a device that will convert HDMI to digital RF.
This will also require to purchase indoor digital antenna.
HDM68(9) is around 20-40$.
The HDMI to Digital RF starts at 110$.
This solution is also unencrypted and can be a good solution for public areas. like a sports bar.
Search words for this device are:
You are correct in your summary and usage scenario for broadcasting HD content over RF, especially in public spaces like sports bars. Here’s what you outlined:
  • HDMI Extender over WiFi: Good for point-to-point streaming but not for broadcasting to multiple TVs.
  • HDMI to Digital RF (Modulator, e.g., HDMI to ATSC RF Modulator): This converts an HDMI signal to a digital TV signal (ATSC), which can be broadcast over standard coaxial cabling and received by multiple TVs with digital tuners. These modulators start at around $110.
  • HDM68 Device: An affordable device ($20-40) referenced as part of another solution, possibly for analog or limited digital applications.
  • Requires Indoor Digital Antenna: Needed to distribute the RF signal to TVs.
  • No Encryption: Makes it ideal for public areas since there are no limitations on receiver compatibility.
Key search terms: “HDMI to ATSC RF modulator”
If you need more specifics on setup, brands, or technical details—or want to compare options in more detail—let me know!
