djnero6
I have a computer problem that win 7 7077 will no longer be able to install, shows error code 0x80070241 ....
otherwise I used the DVD (2x burning), and both USB, but it does not work ... what more can be :frown:
To install and worked well from the 7000, 7022, 7057, the 7068th
Please help me how to get rid of ...
Thanks for any help would be ...
Mr., Henno
cmn
Mr., Henno
It may be due to corrupt file in the original download from the "wild" and not due to any error on your part in creating the disc or USB flash drive to install the Beta OS or your system's environment.
The differences between these various Builds are not that significant except some 705N builds which were really horrible.
Accordingto all indications from internet news, Win7 RC is less than 2 weeks away. So, may be you can try the other builds to find what is good and what you don't like about Win 7 :-)
djnero6
Thanks for the information... :)
