Drew
Banned
This is pretty much what I requested from the Win8 Build Team.
W/ this, no more need for the previous separate Shut Down & Restart buttons; although they can stay on Start, as tiles. And, better than Alt+F4...better than anything, really. Way better than, Charms>Settings!
Still hope we see it embedded in next versions of the OS.
Have deleted the Shut Down & Restart buttons from Quick Launch, now.
Put the Power button on the Sys Tray
Rt Clk (it) > About
Check (box) "Start w/ Desktop"
Now will be permanently there following reboots
NPowerTray
Enjoy!!
And, here's another view, also, showing use of Desktop Toolbar which, makes drilling down to ____ a cinch.
It seems like you are discussing some customization options and enhancements related to Windows 8. Here's a breakdown of the various points you mentioned: 1. Consolidated Shut Down & Restart Options: - It appears that you requested a feature from the Windows 8 Build Team that would integrate the Shut Down and Restart functions into a single, more convenient option. - This consolidated option eliminates the need for separate Shut Down and Restart buttons, with the possibility of these functions remaining as tiles on the Start menu. 2. Improved User Experience: - This new functionality is said to be superior to the traditional methods like using Alt+F4 or navigating through the Charms bar to access Settings. - The convenience of this new feature is appreciated, and there is hope for its integration into future versions of the operating system. 3. Customization Steps: - You mentioned specific steps to customize the Windows interface: - Removing the Shut Down & Restart buttons from Quick Launch. - Placing the Power button on the System Tray. - Right-clicking on it for more options, such as "About." - Checking the "Start with Desktop" option to ensure the desired desktop view on startup. 4. NPoweryTray: - The mention of "NPowerTray" suggests that this could be a utility or tool that assists in managing power-related options conveniently in the System Tray. 5. Desktop Toolbar: - Additionally, you mentioned utilizing the Desktop Toolbar to streamline navigation to a certain destination, making it more straightforward. It seems like you've found a set of configurations and tools that enhance your Windows experience. These customizations can improve efficiency and accessibility, providing a more tailored workflow. Thank you for sharing these insights! If you have any questions or need further assistance with Windows customization, feel free to ask.
