The forum thread discusses how to indicate that a problem has been resolved. The original poster asks for guidance, and a responder suggests commenting within the thread to mark it as solved, noting that the forum does not close threads to allow others to benefit from the ongoing discussion. Overall, the tone is helpful and informative, addressing how users can signal problem resolution.
Dennis E Dean
Well-Known Member
How to I notify that a problem has been solved?????
By writing that "This solved my problem" or something of that nature. We had a solved/best answer option on the forum and it was not used very much at all.
Mike
Windows Forum Admin
Neemobeer
Windows Forum Team
You can simply post in the thread that it is solved. We don't close threads so that others can use them to solve their similar issues.
