The thread discusses issues with a j5create 7-port USB 3.0 hub on a new Windows 10 Dell laptop, with the original poster experiencing inconsistent port functionality. Respondents suggest that brand and build quality impact hub reliability, recommending brands like Anker and StarTech for better quality. Overall, the conversation indicates that not all USB hubs are equal, and selecting reputable brands can help mitigate connectivity problems.
BudVitoff
Honorable Member
Running a new Dell laptop under Win10.
I have a j5create powered 7-port 3.0 hub that seems to have a mind of its own. Sometimes all ports work, sometimes none of them work, and the rest of the time -- well, you get the idea. The PC is new, the cable connections are solid, it's plugged into a surge protector, everything looks okay.
I don't even know how to ask this, but: Are there good hubs and bad hubs? Is there any general rule to follow when buying/using them? Is this a Windows thing, or do other platforms have the same problem?
FWIW, one computer in the family is a Macbook pro with only two USB ports, so a hub is absolutely essential. This hub works perfectly, yet there is one app that specifies that its dongle must be plugged directly into the computer -- it will not work if it's plugged into the hub!
Josephur
Windows Forum Admin
J5create isn't a horrible brand, maybe you got a bunk hub. There are good and bad hubs, but usually this is based on brand/build quality.
BudVitoff
Honorable Member
Thread Author #3
Apparently, you have the experience to judge the j5create as "not a horrible brand". Are you in a position to give me your opinion as to the highest quality brand out there?
Josephur
Windows Forum Admin
