Asgar Ali
Beloved mister, I'm just a fresh to work with the Home's microsoft windows 7. I needed to work with this gboxapp at my Computer. Therefore i obtained a gboxapp by its web page: gboxapp.com & are already employing this use having joy. nevertheless now the nephew deleted this device from your desktop. once i check out regulate section, I came across the item that this application is due to ionstalled. but I truly do unable to carry the appliance from the desktop computer. I knew to search in google "gboxapp" many reviews tend to be coming. Perhaps there is one exactly who can really help me?
It seems like you're having trouble with a software application called "gboxapp" on your Windows 7 computer. If you're unable to find the shortcut on your desktop but the application is still installed, you can try the following steps to create a new shortcut or access the application: 1. Search for the Application: - Use the search function in Windows to locate the installed gboxapp. Click on the Windows Start button and type "gboxapp" in the search bar. It should show up in the search results if it's installed. 2. Create a Desktop Shortcut: - Once you've located the application using the search function, you can create a new desktop shortcut for easy access: - Right-click on the application in the search results. - Choose...
It seems like you're having trouble with a software application called "gboxapp" on your Windows 7 computer. If you're unable to find the shortcut on your desktop but the application is still installed, you can try the following steps to create a new shortcut or access the application: 1. Search for the Application: - Use the search function in Windows to locate the installed gboxapp. Click on the Windows Start button and type "gboxapp" in the search bar. It should show up in the search results if it's installed. 2. Create a Desktop Shortcut: - Once you've located the application using the search function, you can create a new desktop shortcut for easy access: - Right-click on the application in the search results. - Choose "Send to" and then "Desktop (create shortcut)". 3. Pin to Taskbar or Start Menu: - You can also pin the application to the Taskbar or Start Menu for quick access: - Right-click on the application. - Select either "Pin to Taskbar" or "Pin to Start Menu". 4. Reinstall the Application: - If the above steps don't work, you may consider reinstalling the gboxapp from the official website: gboxapp.com. 5. Check Program Files: - You can also check the Program Files folder to ensure the application is installed. Navigate to C:\Program Files or C:\Program Files (x86) and look for the gboxapp folder. By following these steps, you should be able to either create a new shortcut for gboxapp on your desktop or access it through the Start Menu or Taskbar. If you encounter any specific issues during these steps, feel free to provide more details for further assistance.
