Sucitivel
So, when I ordered my computer I saw that I'd have 1TB of storage. I see that the default area where things are installed (C:\) only consists of 149 GB total, while the Data (D:\) drive has a total of 780 GB. I'd like to move some files over there, but I'm not sure what I should do. I would also like to know, is there any way to transfer GB from D: to C:?
nmsuk
You could use G parted to resize the partitions, but why when you can just change where things gets installed via the installers when you install apps. As an example my system drive is 120GB and contains only windows, all apps and games are insttalled though to my 1TB D: drive.
Sucitivel
So would it be safe to move my Program Files (x86) folder to the D: drive?
nmsuk
No you need to leave that on the c drive. but can install anything you want on D:
nmsuk
you can move dyugg from your user folder to D: so downloads etc.
