I was wondering how I would hide my hard drive from being seen by other users but still be visible to me when I am logged on. I have searched endlessly for an answer to no avail. Most of what I've gathered is that you can hide the drives but they wont be seen by any of the users and you can still access them. But I would like to hide them from specific users. Any help would be greatly appreciated! Thank You in Advance, Richard
The thread discusses methods to hide hard drives from specific users in Windows, with the original poster seeking solutions to hide drives selectively while keeping them accessible to themselves. Responses suggest using account permissions, disabling read/write access, or modifying the registry to hide drive icons, noting that these methods can effectively restrict visibility but may require technical knowledge. Overall, the discussion provides various approaches, highlighting that customizing drive visibility involves balancing ease of use and technical complexity.
You can also use the registry to Hide Drive Icons
The only way to then access them would be to manually type in a path in Start, Run for instance. Or using DOS to navigate to that drive letter. If you couple this with NTFS permissions you can hide a drive pretty effectively.
It is a tad bit of a hassle to configure however, and you have to understand Hex codes. Although I did find a site that calculates the value needed in the registry here:
Link Removed - Invalid URL
It also includes directions on how to setup the hide drives registry key.
- Joined
- Oct 31, 2009
- Messages
- 1,050
which version of Windows 7 are you running some verisons have better security options then others
so you want to be able to hide the hard drive from other users on your local machine am I correct.
Highwayman
- Joined
- Jun 3, 2009
- Messages
- 3,958
errm well if you have multiple accounts you can disable read and write access to accounts specified on the drive's properties
- Joined
- Aug 3, 2010
- Messages
- 1,283
