The thread discusses a tutorial for installing Snow Leopard (Mac OS X 10.6) alongside an existing Leopard (10.5) installation on separate hard disks. The original post provides detailed steps, including preparing two disks, downloading required files, partitioning the second disk, and setting ownership via Terminal commands. A recent summary highlights these key points, noting that some links are no longer available, and users may need to find resources independently; overall, the sentiment is informational and helpful for those attempting this dual-boot setup.
Adamsappleone
U.S.Navy D.A.V.
In the following tutorial we used Snow Leopard build 10A432 GM release (now confirmed that retail disc is build 10A432). Snow Leopard needs a Leopard Install so we need to two hard disk one with Leopard already installed and second hard disk for Snow Leopard. Also you need to download some files needed during the installation so download the files given below. We'll update these files regularly when the new updates will available.
  • Modbin Kernel, Tools, Kexts, Chameleon 2.0 And Boot file Link Removed
  • SMBios.plist
  • Mac OS X 10.6 Snow leopard (Google is Your F.R.I.E.N.D.)
Step One). Connect both of your Hard Disk one is blank and one is pre loaded with Leopard (10.5.X) already. Boot in to Leopard and launch Disk Utility to partition your second hard-disk with GUID partition scheme. Name the partition what ever you want in this tutorial we assumed Snow.
Link Removed - Invalid URL
  • Make sure that the new volume's root directory is owned by the root user, just perform the following commands in terminal.
Complete Tutorial @ Link Removed
The tutorial you referenced provides a detailed guide for installing Snow Leopard (Mac OS X 10.6) on a separate hard disk alongside an existing Leopard (Mac OS X 10.5) installation. Here's a summary of the key steps outlined in the tutorial: 1. Requirements: - Two hard disks: one with Leopard installed and another for Snow Leopard. - Downloaded files, including Modbin Kernel, Tools, Kexts, Chameleon 2.0, Boot file, and SMBios.plist. 2. Partitioning the Second Hard Disk: - Boot into Leopard and use Disk Utility to partition the second hard disk with a GUID partition scheme. - Name the partition as per your choice. In the tutorial, it is assumed to be named "Snow." 3. Commands for Terminal: - Ensure that the root...
The tutorial you referenced provides a detailed guide for installing Snow Leopard (Mac OS X 10.6) on a separate hard disk alongside an existing Leopard (Mac OS X 10.5) installation. Here's a summary of the key steps outlined in the tutorial: 1. Requirements: - Two hard disks: one with Leopard installed and another for Snow Leopard. - Downloaded files, including Modbin Kernel, Tools, Kexts, Chameleon 2.0, Boot file, and SMBios.plist. 2. Partitioning the Second Hard Disk: - Boot into Leopard and use Disk Utility to partition the second hard disk with a GUID partition scheme. - Name the partition as per your choice. In the tutorial, it is assumed to be named "Snow." 3. Commands for Terminal: - Ensure that the root directory of the new volume is owned by the root user by executing specific commands in the Terminal. Unfortunately, some of the links in the tutorial have been removed or are invalid. You may need to search for the necessary files and resources independently to proceed with the installation. If you require further assistance or clarification on any specific steps, feel free to ask!
