Adamsappleone
U.S.Navy D.A.V.
- Joined
- Aug 2, 2009
- Messages
- 1,642
Complete Tutorial @ Link RemovedIn the following tutorial we used Snow Leopard build 10A432 GM release (now confirmed that retail disc is build 10A432). Snow Leopard needs a Leopard Install so we need to two hard disk one with Leopard already installed and second hard disk for Snow Leopard. Also you need to download some files needed during the installation so download the files given below. We'll update these files regularly when the new updates will available.
- Modbin Kernel, Tools, Kexts, Chameleon 2.0 And Boot file Link Removed
- SMBios.plist
- Mac OS X 10.6 Snow leopard (Google is Your F.R.I.E.N.D.)
Step One). Connect both of your Hard Disk one is blank and one is pre loaded with Leopard (10.5.X) already. Boot in to Leopard and launch Disk Utility to partition your second hard-disk with GUID partition scheme. Name the partition what ever you want in this tutorial we assumed Snow.
Link Removed - Invalid URL
- Make sure that the new volume's root directory is owned by the root user, just perform the following commands in terminal.
