anotherwindowsuser
Well-Known Member
- Joined
- Jun 3, 2020
- Messages
- 345
Whilst using kdenlive in Windows 10 (I asked on a Linux forum as KDE is from Linux but had no responses) I have put together some slide-shows and the setup is hidef 1080p 24fps which is then rendered to mpeg2 and the issue I find is as follows, there are two pictures that are placed on either side of the screen and in the centre of the screen a slide-show of a set of other pictures. For some reason some of the slide-show pictures go on the screen with a size and dimension that is not proper, they seem a bit stretched from left to right but they do quickly shrink back to the proper shape. Any ideas? Thanks in advance.
