The thread discusses a new user's issue with Lotus Notes 8.5.x, encountering an error message related to security or file locking after installation. The user seeks a workaround for deploying to 30 users soon. A respondent suggests running the installer in Windows Vista compatibility mode and mentions using Gnumeric freeware as a helpful tool for opening Lotus files.
julyrih
I am a newbie to Lotus notes 8.5.x and the issue I am running into is that after the install it throws an error "You are not allowed to perform this operation" I did some reading an it has let me to believe that the .nsf is lock with some security features. I would like to know a work around because I have 30 user who will be going live in the following months. I will appreciate the help.
Mike
Windows Forum Admin
Can you try running the installer in Windows Vista compatibility mode?
Also, if you ever have problems opening Lotus files, use Gnumeric freeware.
