The thread discusses why onboard graphics memory ranges appear on the PCI bus in device manager, despite using shared system RAM on a netbook without a dedicated GPU. The original poster questions whether these addresses are shown on the PCI bus due to the card being a PCI device, and seeks clarification. A responder explains that integrated GPUs built into the CPU are controlled by the motherboard's northbridge, which connects via PCIe, making the shared resources visible in this way; the overall sentiment confirms that this is normal behavior.
RJSmith92
Hello,
I looked in device manager on my netbook that has no dedicated graphics card (so no dedicated VRAM) and uses shared system RAM as it’s video buffer, the following memory ranges have been assigned to the on board card -
If I then change the view in device manager to ‘Resources by type’, Windows shows the following memory ranges to be on the PCI bus -
Basically all the memory ranges that have been assigned to the card are shown to be also on the PCI bus. I would understand this with a dedicated graphics card where data needs to be forwarded onto the PCI bus but I know my netbook is using system memory as the frame buffer which then I assume the card reads from there.
Do you know why these addresses are shown to be on the PCI bus, is it just because the card is a PCI device so it’s easier for Windows just to display them as if they were on that bus, and anything written to these address will still go into system memory?
I know it’s a bit of a random question but I’ve been trying to find an answer online and can’t seem to find anything.
Any help would be appreciated,
Thanks.
iGPUs and the northbridge used to be on the mainboard, and PCIe is "express" because it runs through the northbridge, not the southbridge like legacy PCI. Then Intel started putting the northbridge in the CPU, which made iGPUs on the CPU die also viable. So even though the GPU is built into the CPU, it's still controlled by the norrhbridge, and that's why your integrated graphics shares resources with the PCIe bus, as you suspected. Don't worry, what you're seeing on your laptop is normal.
Sorry I can't be more concise, but I hope that helps.
Sent from my VS988 using Tapatalk
DevilSlayerDante
Well-Known Member
