Steven Luppino
- Joined
- Jun 15, 2016
- Messages
- 15
I need some advice to find out why my pc headphones don't produce the same sound as the stereo speakers on my pc.
I tried a number of different headphones which all produce the same result as in a markedly different, much less basey, less loud, very tinny sound, certainly much different to the overall shape and loudness you would get from the speakers.
I was just wondering if I had anything not properly set in the audio settings (which is already set to headphones) or something else in that order or if there was anything else such as the specifications or properties of the headphones themselves that you have to look out for when you shop for them in order to get the sounds both coming from the headphones and the speakers to sound about the same. I was also curios if many others had the same problem.
Any thoughts about this matter would be appreciated.
Thanks.
Thanks.
