Russell
Active Member
- Joined
- Jul 21, 2018
- Messages
- 28
Attention: windowsForum users:
When you are using the "su" command at the Debian version 9.5 Linux prompt, you must use your root password. When you are using the "sudo" command, you must use your user password. If you use your root password for the "sudo" command, you will get a few retries to enter the correct password, and then you will receive the following error message ( if you fail to enter the correct password ):
"User <username> is not in the sudoers file. This incident will be reported."
Try not to get confused when to use the root password and when to use the user password. Keep in touch.🙂
Sincerely in Christ,
Russell E. Willis
P.S. - Please read Proverbs 23:23.
"23 Buy truth, and do not sell it; buy wisdom, instruction, and understanding."
[ Proverbs 23:23; RSV ]
Russell E. Willis
3559 Almanac Road
Tallahassee, Florida 32309
Russell E. Willis
Russell E. Willis
3559 Almanac Road
