I went ahead and disabled the rest of the drives in NTFS-config, and then rebooted. I was alarmed that it stalled on the first screen of the BIOS run, while detecting drives. I had to wait over a minute for it to proceed, but when it started booting Kubuntu, it still dropped to shell again. Therefore, I'm guessing that the problem is not related to NTFS configuration, but then when I re-opened NTFS, while it doesn't list the drives, it does list the partitions that I had disabled previously.
Yeah that is a bit odd, it may be related to your dist upgrade from 13.04 to 13.10
I now have HD Tune running diagnostic on the Kubuntu drive, and the initial benchmark wasn't too good, so I'm now running an error scan on it. During the BIOS detection, most of the delay was on SATA3-1, but I'm not certain as to how that relates to the way that Disk Managment numbers them, because it starts at disk 0 instead of 1. Kubuntu is installed on disk 1 according to Disk Management, so I'm waiting to see how the scan turns out.
Do you know how to correlate the drive numbers as given in the BIOS versus as in Windows or Kubuntu?
HD Tune is mainly tuned for windows, not Kubuntu.or other linuxes
I would ignore its results on hard drive health
As for drive numbers in Kubuntu vs windows there is a lot of things to consider here.
Windows labels drives via the alphabet, A and B drives are reserved for floppies (snicker, floppies, LOL!)
C is reserved for the primary partition and other drive letters are reseved for things like USB drives, DVD drives and the like.
Linux on the other hand has a different method.
the first drive its installed on is usually referred to as SDA or SCSI drive A, sure SCSI drives are just as dead as floppies but the moniker SD a catchall for all unix based OS drives. (even linux which is unix like)
I usually see linux install in SDA6 or 5, its rarely a SDA1
The drives in linux are numbered and not really numbered.
I will get to your other issues here soon but I am eating right now, so keep an eye on this topic for edits.
Edit:
Okay done eating, sorry for all the late replies here as i was making dinner and eating, hey I am one person here who is trying to help you and a guys gotta eat.
Anyhow like i said I would not trust HD Tune to test the Kubuntu drive, the drive could be perfectly fine and HD Tune as I meantioned is probably made for windows and is not good at testing non windows drives.
There are tools in linux to test the drives, I would use them as they are made for linux.
There is gnome disk utility and badblocks, one is a gui and one is a command line one.
guess what one I reccomend you install
Gnome disk utility is a tool mainly for gnome so if it sticks out like a sore thumb where there you go.
You can use any tool/app/ whatever made for Ubuntu in kubuntu and vice versa.
